Fuel Gauge Problems
Old Nov 23, 2010 | 09:43 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Fuel Gauge Problems
Recently I installed some new gauges in my car. The previous cluster didn't work at all. anyhow, one gauge refuses to work correctly. I've tried another gauge and the same problem persists. this leads me to believe that the problem is the sending unit. I Go to the Junkyard all the time, but there are some things that i don't prefer to use from the junkyard. A Fuel sender would be one of those things. I would prefer a new one, especially if i have to drop the fuel tank to install it. Do you guys know where i could find a new sender?
Old Nov 24, 2010 | 12:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I would want to do some more troubleshooting before going that far. Do you have a multimeter, with voltage and resistance modes? If not, buy or borrow one (they aren't more than $10-$20 for a decent one). Check the resistance across the sender wires back by the tank. If open, then you probably have a problem either with the wires or the sender that would require dropping the tank.
If you do have resistance, then check for voltage from the chassis side of the connector. If you don't have voltage, then find out why.
I don't know of a source for a new sending unit. I have one that worked when removed (converted to LS1, put in an EFI sending unit).
Old Nov 24, 2010 | 10:38 PM
marine68's Avatar
Car: 89 IROC Z28
Engine: 5.7 L Edelbrock perf /holley 3310
Axle/Gears: BW 9 BOLT 3:27
Re: Fuel Gauge Problems
spectra premium makes new fuel tank senders, all the auto parts carry them, i bought one for my 89 iroc for about $150.00
Old Nov 24, 2010 | 11:11 PM
ChromePhoenix's Avatar
Car: 85 Trans am
Engine: 350 carbed
Axle/Gears: 9 bolt rear disk
this is one i had saved previously. its something ive been battling with and dread dropping the tank. but it might save you some time.
https://www.thirdgen.org/forums/elec...tuck-full.html
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
