Holley 3310 jetting
Car: 89iroc-z 97-firebird
Holley 3310 jetting
Will a roller cam make "oem" jetting way off on a Holley 3310?
5,7 / 350 roller cam, ported heads intake (1500-5500) headers 5speed
I "need" a good power making jetting advise, newer mind the mpg
jets power valwe sec.spring
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Holley 3310 jetting
The fact that its a roller cam VS flat tappet will make no difference to the carb - it will never know the difference. The cam specs, however, can make a very big difference to the carb.
What are the specs of the cam you want to use? What are the specs of the rest of the motor? I used a Holley 3310 for a long time on the 350 I used to have before I sold that engine to put the big block in - excellent carb, I should never have let it go!
Comp cams CCA-08-422-8.
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 1,600-5,400
Intake Duration at 050 inch Lift 218
Exhaust Duration at 050 inch Lift 224
Duration at 050 inch Lift 218 int./224 exh.
Advertised Intake Duration 270
Advertised Exhaust Duration 276
Advertised Duration 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.495 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.502 in.
Valve Lift with Factory Rocker Arm Ratio 0.495 int./0.502 exh.
Lobe Separation (degrees) 110
10.3:1 comp. ported heads, (flow enough to produce +450hp sad the guy that flow tested them after i was donne. if this combo makes 350hp i'm glad -400hp i'm thrilled) intake same rpm as camchaft, headders.
any other info needed that i left out?
You'll have to fine tune it yourself, but I'd start with 71 front jets and 76 or 78 rear jets as a baseline. Powervalve - you'll need a vacuum guage to figure out which one you need.
Transmission: 4L80E/4L80E
Expect better results if you use one of these: http://www.summitracing.com/search/?...0housing&dds=1
A 5-speed should have a double pumper carb, not vacuum secondary.
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
It will be reasonably close out of the box, in that it should start and run ok, but as with any engine it could be put on, it will need some tuning to get it just right. There is no universal calibration that works with every combo out there.
Thats also assuming the carb is actually new and coming out of a box. Those carbs have been made for over 45 years, so there are lots of used ones out there as well, all with different calibrations on them.
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Once he drives it he will have to figure what it needs, if any.
Looking back many yrs had a combo similar to his same carb tried a 750 DP also. Didnt know much on tuning...car ran great except for a slight flat spot off idle....a slightly bigger squirter woulda cured it but ignorance is bliss...ah, bigger pumps jets power valves, etc. Basically the car never ran right after that and fouled plugs LOL
OP keep us posted, sure someone will guide you in the right direction should it not be spot on.
Ditto on DP litle more gearbox friendly...if you DO have the VS theres always a quick change kit for the springs IF it even needs it. VS carbs are nice and smooth Ill give it that much, nice to drive
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
86CamaroDan
Sep 29, 2015 10:08 PM
3310, 3310c, 3310s, 355, calibration, difference, factory, holley, holley3310, jet, jets, jetting, size, specs, tuning
its all trial and error.. anyone can guess a jet size but it varies according to the engine and how far you are from sea level.. just to many variables to guess
