Only 1 line coming from tank to carb?
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Am I missing something here? My 89 GTA was converted to a carb setup. Guy installed an electric pump, not sure how many PSI but I think it may be too much. He did the typical hack job on the hatch area to access the tank pump, but upon getting under the car, I only see 1 line going into the fuel pump, and out to the carb. There are also 2 lines just sitting there and sometimes are wet on the ends like fuel has been coming out of them, not only that, I can smell fuel heavily when taking moderate turns. Do I need to cap off these lines? Did they do this wrong? If any pics are needed I can get some.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Re: Only 1 line coming from tank to carb?
The factory tank should have 4 lines comming from it.
1. vent
2. fuel supply
3. fuel return
4. some other line
You probably are using the factory feed for your pump leaving the other three lines exposed. Mine were like this for quite some time with no issues. I just recently welded everyone but the vent shut. See my thread in the racing forum about "adding a sump" for pictures.
If your seeing/smelling fuel around turns it's probably a bad seal around the top of the sending unit. It's common and should be changed for around $10. You should make a project out of pulling the tank, changing the seal and closing the lines.
What kind of pump is it? A lot of those mechanical carb pumps have internal regulators in them which don't require return lines. Thats how mine was. Do you have a fuel pressure guage? What does it read?
1. vent
2. fuel supply
3. fuel return
4. some other line
Transmission: 4L80E/4L80E
1. vent
2. fuel supply
3. fuel return
4. some other line
1. vent
2. fuel supply
3. fuel return
4. some other line
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
