Factory pump to carb questions.
Old Dec 12, 2010 | 01:03 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
I carbed my '88 firebird about a year ago and went through the trouble of doing it right with a diaphragm regulator and all that other jazz. Now because I know the factory pumps aren't exactly known for their longevity, I want to examine my options for replacement.
I've read in a thread here on TGO that somebody actually rigged up a mechanical pump and ran it through his factory return line. How feasible is this? Will this still pull fuel until the tank is empty? Will I need a vented cap?
On a sidenote, if this IS in fact a possibility (I'd like to avoid dropping the tank. That's a buttload of work I could do without) will a L31 out of a '96 suburban come with the proper cam lobe to support a mechanical pump? and if not is it feasible to use an electric fuel pump out of the return line?
Thanks for your input.
Old Dec 12, 2010 | 07:40 AM
Damon's Avatar
Re: Factory pump to carb questions.
Fuel pump lobes started disappearing from factory installed cams in the early 90s. So, no, I doubt the cam in that Vortec motor would have a fuel pump lobe.
Also, you can't just bolt on a mechanical pump and draw through a non-functional factory in-tank (too much restriction). Never paid that much attention to the return line but I seriously dobt it goes all the way to the bottom of the tank like the pickup side does.
Old Dec 12, 2010 | 11:10 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A factory L31 block likely isn't machined for the mechanical pump. Some may have been, but I've never seen one that was.
Old Dec 20, 2010 | 05:34 PM
vorteciroc's Avatar
Top Answer: 1
From the L31 blocks i have used in my cars, the 96-97 blocks had provisions for a mechanical fuel pump push rod... the 98+ blocks do not have a hole drilled for the push rod. All have a mounting boss.
Infested
May 22, 2018 11:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
