Starter Wiring Diagram
Old Dec 20, 2010 | 11:53 AM
oguin_studking's Avatar
Car: 1990 Firebird Formula
Engine: 358
Transmission: 700-r4
I have looked everywhere & cannot find a decent wiring diagram for the starter. I have redone almost all of my wiring. I labeled most of the wires. The problem is it rains so much where I live that it washed all the ink off of the masking tape bc all my work outside. I I know which wires go to the starter i just dont know which wire goes where on the starter. If someone could help that would be awesome!
Old Dec 20, 2010 | 12:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Starter Wiring Diagram
Your starter should have 2 terminals, a larger one and a smaller one. Everything connects onto the larger terminal EXCEPT the purple wire, which connects to the smaller one.
Old Dec 20, 2010 | 12:40 PM
Engine: 358
Awesome...i know that i have 2 connected to the small one so that is def. wrong! thanks man!
Old Dec 20, 2010 | 01:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Let's make it simpler - the ones with the large eyelets go to the large terminal along with the positive battery cable, and the ones with the small eyelets go to the small "S" terminal.
I haven't seen it personally, but I believe I've heard that TBI cars had a second wire on the same terminal as the purple start wire.
Old Dec 20, 2010 | 03:21 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Diagram attached.
File Type: pdf
Old Dec 21, 2010 | 02:49 PM
five7kid's Avatar
That doesn't show 2 wires on the "S" terminal, so perhaps I was remembering incorrectly.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
