Carburetors and Cavity Creeps
1 Post
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
I'm sure i'm aging myself with the Cavity Creeps term, but i thought i would share a tip with you guys if you didn't know it already. I was cleaning my Rochester 2 Jet and when i got to the Vacuum Bell, i knew i couldn't just drop that into the caustic chemicals that i was using for the other parts. The Rubber probably wasn't like new, but i was sure that i would destroy it with the chemicals. then it hit me. i've been using a toothbrush for the little nooks and crevices. why not use toothpaste. It worked VERY well. give it a try.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Carburetors and Cavity Creeps
You mean like the vacuum brake/choke pull-off? Carburetor cleaner doesn't hurt the diaphragm, you can use it for the outside. I wouldn't immerse it though, it's tough to get it all out from inside.
1 Post
Yes, the vacuum brake/choke pull-off is exactly what i meant. another plus is that it has a minty fresh smell afterwards.
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
Ahaha...I used heavy duty dish soap with HOT water when I cleaned my qjet when I rebuilt it. But toothpaste??? Mm..I dunno.
I still went back over and used carb cleaner after the soap treatment to get rid of any residue from the soap.
Darth Mole
09-21-2015 09:48 AM
GeneralIesrussi
09-03-2015 03:23 AM
