tbi to carb
Old Dec 28, 2010 | 09:35 PM
IROCZdude's Avatar
Car: 88' Z
Engine: 350 .60 over
Transmission: W/C T5
tbi to carb
i know everything i have to do with lines vaccums and regulators ect..
now what do i do with the wires from my tbi, like the iac, tps, ect..
second, is there anything i should know about the electrical side of the swap?
Old Dec 28, 2010 | 10:55 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tbi to carb
With the computer gone they don't do anything.
Some keep them in the car in case they want to change back / some cut them out
Old Dec 29, 2010 | 08:33 AM
89redliningRS's Avatar
Re: tbi to carb
I posted that I had a wiring harness for a tbi setup on the parts for sale board and people bought parts of it off my car. So I just cut the peices they wanted and made some money back. You just need to switch to a non computer controlled HEI dist. I found a great deal on the Jegs Street/strip hei. Sells for around $100, loooks just like a msd. Then put in a fuel pressure regulator to keep the pressure down.
Old Dec 29, 2010 | 09:44 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: tbi to carb
all the sensor wiring comes from the passenger side and can be removed as one complete harness, no cutting required. a non CC distributor will be needed and just need to get power to it. you said you've already got the fpr figured out (and you will need to rewire the fuel pump relay to get power). don't forget the TC lockup as well since you're pulling the engine computer
Old Dec 31, 2010 | 11:49 AM
ChrisJ91RS's Avatar
Car: 1991 Camaro RS
Transmission: Stalled 700R4
Axle/Gears: 3.23 Posi
Re: tbi to carb
I am doing to same swap, and I already understand everything about the swap except on the fuel pump rewire, how do I do that?
Thanks, Chris
Old Dec 31, 2010 | 12:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: tbi to carb
Chris: What I did on mine was use the OEM fuel pump relay and the wires from the oil pressure sending unit. The OPSU originally has 3 wires on your car, one for the guage (a small wire), and 2 for the fuel pump (1 in and 1 out - the one in comes from the battery, other goes straight to pump). I cut the wires from the relay, and the larger 2 wires from the OPSU. Wired the relay as 1) a ground, 2) a hot-in-run, 3) wire #1 from OPSU, 4) wire #2 from OPSU.
So - when you turn key on, the hot-in-run activates the relay, which in turn makes the connection between the two OPSU wires, and runs the pump.
This makes the pump run as long as the key is on. AND - this takes the OPSU out of the fuel pump equation - I've had the OPSU go bad, making the pump run all the time util it kills the battery, and I've also had it go bad and leave me with no pump, thus taking it out of the fuel pump circuit made sense to me.
As long as that 3rd smaller wire is still connected to the OPSU, you still have a functional oil guage.
Anyway - that's how I did mine. Good Luck!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
