Fuel pressure regulator question.
Old Jan 6, 2011 | 05:26 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I had a holley FPR, single line in, 2 lines out. I blocked off one of the outs with a filler, and ran a line for my carburetor feed. The return line for the tank, I made a filler by brazing shut a piece of 5/16 hose with the special end for that type of flex line.
Is this going to be okay? I did reuse the charcoal canister so I do have a vent, but I do not have a return line to the tank.
Old Jan 7, 2011 | 07:17 PM
Kevman's Avatar
Engine: 2004 LQ4
Re: Fuel pressure regulator question.
Nobody knows?
Maybe if I ask how rare my 1991 IROC-Z convertible is?
Old Jan 7, 2011 | 07:23 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
if it has 1 inlet and 2 outlets it must be a bypass regulator pn 12-803bp? what fuel pump are you using?
Old Jan 7, 2011 | 07:25 PM
Kevman's Avatar
Engine: 2004 LQ4
The stock 15 PSI TBI in tank pump.
Old Jan 7, 2011 | 07:26 PM
ok. you will need to run a return line. otherwise you may get too much pressure.
Old Jan 7, 2011 | 07:36 PM
Kevman's Avatar
Engine: 2004 LQ4
What I may do, is use a 3 prong fuel filter (My 86 plymouth has one) and use the 3rd prong to my return line.. For 7$, it's the easiest way.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
