Rochester Quadrajet 750cfm
Old Feb 28, 2011 | 10:35 PM
dtk132's Avatar
Car: 1986 Camaro
Engine: 350ci 5.7L
Transmission: T-5 Borg Warner
Axle/Gears: 10bolt/ 3.42
Hey everyone, I dont know much about carbs. I have a small 450cfm holley on my 350 right now. It originally came with this Rochester Quadrajet i took off not realizing after i read up on it that its actually a pretty good performance carburetor. I had it rebuilt about a year ago and never used it.
It was originally had an automatic transmission with the engine so their is a kickdown on the carb.
I have this engine in my Camaro now but with a manual transmission. Can I hook up this carburetor and make it work even if it was out of an automatic transmission truck?
I dont know much about carburetors so if you would please be able to explain in simple terms for now. I appreciate the help. Thanks
Old Feb 28, 2011 | 11:49 PM
K88-79's Avatar
Car: 88 iroc z28
Engine: Sbc 350
Transmission: 700r4 auto
Axle/Gears: ??????
Re: Rochester Quadrajet 750cfm
I think you'll be ok....the carb doesn't care if there's a kickdown cable or not. (Simply put).
Old Mar 9, 2011 | 07:08 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The automatic application CCC Q-jets don't mind being in front of a stick trans. Neither do the non-CCC ones. Make sure you adjust the secondary air door so you can fully enjoy it.
PurelyPMD
May 5, 2016 04:57 PM
sreZ28
Oct 22, 2015 08:21 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
