305 4bbl carb starting problems
Car: 1987 camaro Z28
Engine: 305 4bll
Bought a carb from national carbs and it came in the mail today
its a model E4ME q-jet
put it in hooked everything up to the best of my ability and it wouldn't start, so i tried again and it started but sounded like air was being pushed out so i stopped the engine to see if something disconnected but everything looked fine, it never started again after that, and it turns over but doesnt fire up
my possible explanations are
it needs carb start spray
a vaccum line isnt hooked up ( theres one i cant find where it goes its about a foot long with a 90 degree bend on the end
it also didnt come with an idle speed Assembly
any help would be sweet its a 1987 camaro 305 H.0. 4bbl
Engine: 305 4bll
Re: 305 4bbl carb starting problems
Yes but it would drive for a few seconds and then flood and shut off, so i got a rebuilt one and put it on but now it tries to start but wont
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The carb was flooding out before you put it on? What fuel pump are you running? Factory Mechanical? There is a diagram on here that shows the vacuum diagram. Like scooter asked, can you post a picture of what you've got hooked up currently?
Car: 87 Camaro Z-28
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
db057
Aug 11, 2015 10:11 PM
