Converting to carb, using EFI fuel pump
Old Jun 18, 2011 | 07:59 PM
Hoff701's Avatar
Car: 1992 Rally Sport
What if you just put an inline regulator between the stock in-tank pump and the carb? I was told I could do this with an aftermarket regulator, such as the Holley 12-803 (no bypass return line to tank)... I got to thinking though, wouldnt the pump just grenade the regulator with the ammount of pressure its pushing? Thats quite a step, going from around 50 psi down to 6.
Old Jun 19, 2011 | 08:39 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Carb gas tank pickup
You'll blow your fittings, your line and you'll probably blow up your pump if you run that much pressure redux with no return. Hook up a bypass regulator, either a Holley or Mallory inline using the factory return line and you'll be fine. I installed an intake pump (255lph) in my carbed car, running a Mallory bypass regulator and I'm sitting at about 6psi. No problems so far.
Old Jun 19, 2011 | 02:42 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: 9 bolt, 3.45
Use a bypass regulator with an intank pump on a carb. On a customers car that was TBI I still used a bypass regulator just because they're better anyway. If your using a TPI pump its a must, dead heading MPFI pump can go upwards of 80 psi. Trying to regulate that down to 6psi without having a bypass will not work well
Old Jun 19, 2011 | 08:23 PM
Hoff701's Avatar
Awesome. Thats a huge relief, cuz i really dont feel like dropping the tank (and the axle) again lol
Thanks for the info
Old Jun 20, 2011 | 01:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Converting to carb, using EFI fuel pump
I moved these posts out of the sticky. The question was inappropriate there.
Old Jul 21, 2012 | 10:44 PM
vaughn5555's Avatar
Ok I have read many post about the fuel regulator and again I'm getting confused. So will some one tell me if I have this right in my head. On my 92 firebird that had a v6 there is one line that goes from the tank to the motor and then a second that goes back to the tank which is the return. All I have to do is use the fuel pump that is already IN the tank and then just install a fuel regulator under the hood and I should be good with my carbed 350.
I'm sorry for asking questions that have already be answered its just easier if I ask how I see it in my mind. Thanks
Old Jul 22, 2012 | 07:28 AM
Ozz1967's Avatar
Car: 1984 Trans Am
You are correct. Generally, the two lines run near each other. The larger line is the fuel line,the smaller line is the return line. The larger line goes to the -8an fitting, the smaller line goes to the bypass side (usually on teh bottom). The directions that come with the regulator will tell you which is which. When you set the regulator at 5.5-6psi, you won't get any more pressure than that through the line.
Old Jul 22, 2012 | 10:34 AM
vaughn5555's Avatar
Thank you for the help. Hopefully I can get started on the car this after noon. I will let everone know how I'm doing on my first project
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
