change over to carb?????
Old Jun 26, 2011 | 02:43 PM
tri power's Avatar
can i change 92 3.1 camaro engine to carb engine if so what intake
Old Jun 26, 2011 | 05:51 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: change over to carb?????
Why?
Old Jun 26, 2011 | 06:10 PM
tri power's Avatar
Because I want a Carb.
Old Jun 26, 2011 | 07:54 PM
Project-RS's Avatar
im sure you can. just have to switch a few things and find a carb that will work well with your motor
Old Jun 28, 2011 | 12:30 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
You can change it over to a carb. I have swapped mine over. I would first say that if my injection was working I would not have swapped the carb on it.
You need to find a 2.8 carbed motor from an s10 or early 2.8 Camaro and get the intake. I got mine from a non computer controlled S10 and grabbed the distributor and air filter housing and carb at the same time. It was a fairly easy swap but you will have some adapting or blocking off for things like the brake booster, egr, and smog as well as all the vacuum lines.
The upper air conditioner compressor bracket will no longer bolt up so that will need a modification.
The carb is a rochester varijet 2 in line 2 barrel. For another alternative see the thread
https://www.thirdgen.org/forums/carb...rb-84-2-a.html .
In this thread a TBI intake is modified to bolt a regular 2 barrel carb on. This allows the original throttle cable to be used with some modifications as well as a better carburetor. Still need the non computer controlled distributer with Vacuum Advance.
Old Jun 28, 2011 | 12:39 PM
91phoenix's Avatar
Should have mentioned the fuel pressure regulator and rewiring for the fuel pump. With the early 2.8 intake I also had to modify the upper radiator hose. The bolts for the carb base are also a real pain to loosen or tighten. I got rid of the electric grid in my base gasket also.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
nuggie
Aug 25, 2015 01:27 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
