carb tune help needed
Old Aug 3, 2011 | 03:29 PM
85z28kid's Avatar
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
So I'm trying to figure out what size jets I need and tune for my 355. The carb is a Barry Grant750 dp. I need to what jet sizes and a tune.
The motor specs are 355 with gm041 heads with work done to them, 454 lift cam on both and 272 duration on both, it's got a torquer 2 intake on it. Its got 10:1 compression and full msd with 34* of advance. Got full length headers also.
Drive train is a turbo 400 with rmvb. It's got a 3000 stall. The rear has 373s with 27.5 inch tires.
Hope you guys can give me a tune with this info thanks in advanced.
Old Aug 3, 2011 | 03:31 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: carb tune help needed
It's not that easy, what came in the carb? How are your plugs burning??? Probably startoff between 70-74???
Old Aug 3, 2011 | 03:46 PM
85z28kid's Avatar
Car: 85 iroc-z28
The carb when I got it came off a late model the jets now are 75 and 80s. It has four corner adjustment for the idle mixture. As for plugs I never thought of pulling a plug but I could and tell you what it looks like. Thanks for the reply
Old Aug 6, 2011 | 01:10 AM
85z28kid's Avatar
Car: 85 iroc-z28
this is what the plug looked like when i ran it with the 75 and 80s. its got a 6.5 powervalve in the front and blocked in the rear. i was thinking of adding 83s to the rear cuz i think its going lean when the secondaries open up. also it has a slight hesitation so i was thinking of maybe putting in a 9.5 powervalve if it would help. also if i dont run atleast 1.5 turns out on the idle mixtures she stumbles really bad so i was thinking of adding bigger squirters. let me no if it would help thanks
Old Aug 6, 2011 | 05:57 AM
J91's Avatar
J91
How about a couple of different plug shots hard to tell from just thst one....
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
