TV Corrector Install Question
Old Aug 9, 2011 | 01:10 PM
Drew_91RS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock 2.73 I think..
I purchased the Holley bracket to correct the pull of the TV cable but the instructions show a different type of linkage than my carb has.
This is what mine looks like
This is the type in the instructions
Heres a link to the intructions http://www.holley.com/data/Products/.../199R10345.pdf
Old Aug 10, 2011 | 01:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Doesn't look like it will fit your throttle arm.
Old Aug 10, 2011 | 02:47 PM
Re: TV Corrector Install Question
The carb in the pic is a boat carb... no wonder it won't accommodate a TV cable, as boats don't generally have those.
Probably be a good idea to get some other carb for your car.
Old Aug 11, 2011 | 07:54 AM
Drew_91RS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Yeah I went to O'Reilly's and talked to them they said it looks like my baseplate is a marine style. The top picture isn't my exact carb, as mine doesn't have the J pipes. My base plate and main body have 2 different finishes.
I believe I can just buy a throttle shaft service kit since it comes with the proper throttle arm.
Old Aug 11, 2011 | 09:45 AM
Sounds like maybe then, you have a carb where somebody swept up the shop floor, assembled all the Holley parts they found into one amalgam, and ... now you have it.
I'd recommend against spending any money on that. There's NO TELLING how much stuff has been changed about it.
Some of the parts (metering blocks in particular) may have the list # stamped on them; if they match the carb list #, there's hope. If not, cut your losses now, and spend your money on some other carb that you don't have to deal with a situation where the first thing you have to do is find all the little hidden gotchas buried in it from where somebody has previously butchered it.
Old Aug 11, 2011 | 02:27 PM
Drew_91RS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I saw the carb in use with the engine I have (350). The guy I bought it from had a turbo 350 with a manual valve body so he never had to worry with the kickdown.
(Bought engine and carb from same guy at the same time)
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
