stalling issue
Old Sep 21, 2011 | 05:54 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
stalling issue
i have a 91 firebird was 305 tbi now 350 carb when im driving the car suddenly starts to sputter rpms drop than shuts off and it happened a few times i have a gm hei dizzy and i put a new coil in aswell as an ignition module does anyone know what i should look for i put the mallory 4309 fpr in so i dont burn out my elec fuel pump but if anyone has any ideas what to look for lmk thanks
the timing is on the money and the fpr is set at 6.5 psi
Old Sep 21, 2011 | 07:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: stalling issue
6.5psi a little steep for a carb, try backing it down to around 5. What brand carb?
Timing dead on what? Can't set timing to factory spec since swapped to a carb - timing should be somewhere around 10-15*BTDC.
Old Sep 21, 2011 | 08:56 PM
Car: 1991 Trans Am
Axle/Gears: Stock
Re: stalling issue
its a edelbrock 600 electric choke my idle is at 700rpm and it runs great except when it sputter and shuts down like it loosing spark
Old Sep 22, 2011 | 05:42 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: stalling issue
Too much psi for an Edelbrock. Manual states 5.5psi- no more.
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
Bryan F
Aug 18, 2015 02:28 PM
