3310holley
Old Sep 23, 2011 | 07:25 PM
1983cameroman's Avatar
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
3310holley
can you secondery plate from 375hp 396 carb on 3310 holleyok for you young people 375hp 396 chevy cam with vac secondary 780 cfm holley what im asking is can aperson use one of these on my 3310 holley do you understand??????
Old Sep 23, 2011 | 07:29 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 3310holley
can you rephrase that into a coherent question please?
Old Sep 23, 2011 | 07:46 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: 3310holley
So you edited it after you were told to and it still doesn't make any sense? What the hell. And why did you put an E in Camaro?
Old Sep 23, 2011 | 07:52 PM
travis401's Avatar
Car: 91 Camaro RS
Re: 3310holley
im guessing your asking of you can use this "396" carb's secondary metering block on your carb? if its the same style carb (holley 4150, 4160, ect) yes, is doesnt matter that its on. if thats the case then yes it will physically fit. will it run great, no telling without specifics on both carbs....
Old Sep 23, 2011 | 07:53 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
Re: 3310holley
for some reason i CAN understand his question lmao
Old Sep 23, 2011 | 07:56 PM
Engine: 468bb
Transmission: 700r
Re: 3310holley
schoolnight put e in camaro to be different second early z 28 came with 780 cfm holley as did 375hp 396 asdid 427 425hp as did 454 460 and 490hp 3310 holleys have plate with no jets 780 has plte or block that you can change ok?
Old Sep 23, 2011 | 07:58 PM
travis401's Avatar
Car: 91 Camaro RS
Re: 3310holley
like i said, it all depends on the MODEL of carb, not what it came on...
Old Sep 23, 2011 | 07:59 PM
Engine: 468bb
Transmission: 700r
Re: 3310holley
you got it thank you 3310 are what holley change these carbs to as the updated version i think ill try it see how it runs
black84-6spdz28
Carburetors
Mar 20, 2003 08:41 AM
