Choke is stuck on
Old Sep 25, 2011 | 05:11 PM
camaro newbie's Avatar
Car: 1984 camaro
Engine: v6
Transmission: 5speed manual
Choke is stuck on
I have an 84 2.8 v6 camaro 5 speed manual (m5)
thanks to cold wisc weather push pedal to floor engage the choke, let it run, then i jab the pedal to shut it off.
Tried jabbing and it didnt go off
its been like two weeks and it still has not turned off
the idle was at 2500 rpms and so i backed out the screw that keeps the choke engaged so it cant set, but the light and annoying buzzer is still on,
when i sit at a red light my idles are under 500 rpms and sounds like it wants to die
also when i try to floor it and race someone the car just stops and doesnt accelerate, but other times the car takes off and feels like my 100 hp engine is going 150hp tire chirp into 3rd.
Old Sep 25, 2011 | 05:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Choke is stuck on
Check the choke heater fuse and then undo your "adjustment".
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tmellott89
Oct 14, 2015 02:06 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
