Low vacuum in gear
Old Oct 22, 2011 | 03:44 PM
lonesomeloser's Avatar
Car: 1983 Z28
Low vacuum in gear
My quadrajet has been re-worked by the local carb guy. Just recently he had to make the idle air tubes larger. I am only pulling 2" of vacuum in gear. What would cause this and how can I get my car to idle when I drop it into gear? I've played with the mixture screws but it still wants drop to 500 rpm in gear and almost die. The cam is .230/.230, .480 lift/ 108 LSA. The carb guy says I need a higher stall torque converter. The converter is a "corvette" one, but I forget the rpm's. Please help, I am so confused.
Old Oct 22, 2011 | 06:59 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Low vacuum in gear
Your carb guy is at least right about one thing: That "Corvette" torque converter isn't nearly enough stall for a 230 cam.
Old Oct 22, 2011 | 07:17 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
yea, your gonna need an aftermarket stall. i would think you should have more than 2 inches of vacuum though.
Old Oct 22, 2011 | 09:16 PM
Car: 1983 Z28
Thanks for the input, guys. The carb guy said he has spoken to a few people about my car, and they are surprised it even runs. That made my day, geez. So what would cause such a low vacuum? At idle, it's 12". Should it improve with a converter with a higher stall? What do you guys recommend?
jklein337
Sep 19, 2018 06:23 PM
perZ
Aug 21, 2015 05:51 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
mizz0313
Aug 12, 2015 06:45 AM
