Switched Air horns
Old Dec 10, 2011 | 10:20 PM
JLCustomizing's Avatar
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
Switched Air horns
After I pulled my carb out of the carb dip I noticed the numbers didnt match between the body and the airhorn. The shaft on the air horn has a little wiggle room and the large covers have maybe 1/16th inch between them and the outter rim. I'm wondering if the wiggle room and the spacing between the covers and the rim are going to mess me up when I finish the carb?
Old Dec 11, 2011 | 06:21 AM
Damon's Avatar
Re: Switched Air horns
You mean the choke plate shaft has play and there is a gap around the secondary air doos? If so, it's not a problem.
Old Dec 11, 2011 | 03:21 PM
Car: 1984 Trans Am
Axle/Gears: Stock
Choke plate seems pretty tight just the secondary flaps seem to have a mild gap. If its not going to cause any problems I'll just leave them be and continue to clean them.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
