MAT Sensor Location, 1986 305 4-bbl Auto Trans
Car: 1986 Trans AM
Engine: LG4-305-Edelbrock Intake/Q-Jet Carb
Transmission: Automatic
Greetings,
Just had a new Edelbrock 3701 Intake Manifold installed and I am now getting Trouble Code 23. MAT Sensor (Low Temp).
My suspicion is that the MAT sensor is supposed to be mounted on the intake manifold itself and either the Edelbrock intake doesn't support it, my Mechanic didn't hook it up or the sensor is bad.
Please let me know which is right, what it is supposed to look like, where it should be attached and the implications if I never hook it up?
Please include a picture or diagram if possible
Thanks,
Big Ed
Thanks,
Big Ed
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: MAT Sensor Location, 1986 305 4-bbl Auto Trans
Greetings,
Thanks,
Big Ed
Thanks,
Big Ed
Transmission: 4L80E/4L80E
https://www.thirdgen.org/service-eng...ht-error-codes
For a carb'd car, code 23 is TPS. Make sure it's plugged in, the harness isn't pinched under something, etc.
Car: 1986 Trans AM
Pardon my ingnorance, but what is a TPS and where does it plug in? Where would I look for it? What does it look like?
Thanks for your help,
Bi Ed.
Bi Ed.
Throttle Position Sensor. White plug on the front driver side corner of the carb.
In the diagram https://www.thirdgen.org/forums/carb...e-rebuild.html , #71.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
