holley up grade??
Old Feb 14, 2012 | 08:02 AM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
holley up grade??
Hey can a holley 600-650 cfm be upgraded to a 750cfm? i was wondering if you could by a kit to do that sort of thing, thanks
Old Feb 14, 2012 | 09:08 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: holley up grade??
You'd have to replace the carb.
Old Feb 14, 2012 | 01:55 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Which Holley is it? With the double pumpers, as far as i know the only difference between the 650 and the 750 is the mainbody. Those can be had individually if you already have a 650 or 750 DP carb laying around... The nice mainbodies arent really cheap, though. Not sure it's really worth the trouble to do all that, but you can do it.
Old Feb 14, 2012 | 06:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Right, the 650 to 750 all use the same throttle body, so a replacement main body will upgrade it. But, I believe the 600s use a different throttle body.
Old Feb 14, 2012 | 06:25 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
cool that sounds good, I think your right though about just replacing it for a new one, but I didnt know for sure, so thought all the tallent on here that someone would know how it worked, thanks
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
Tarizza
Sep 24, 2015 12:57 PM
