88 camaro distributer problem
Car: 88 camaro
Engine: 305 soon to swap to 327
Transmission: 700R4 with raptor kit
Axle/Gears: 3.55
Hi guys I'm doing an EFI to Carb swap on my 1988 iroc camaro,it has a 305 TPI motor and my question is I just got a distributer for it and it's an aftermarket type one where the coil is in the cap the question I have is that there is only a place for one plug to hook up to it and yes I know I've looked at the EFI to Carb swap thred on hear but my coil on my car has 4 wires going to it??? and nun of them from the looks of it are red and pink??? could someone please help me with this,thanks for all of the help guys.
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: 88 camaro distributer problem
it shoud come with one plug on it out of the box (ICM wiring) and it should have two other connections for 12v ignition and one for Tach, they are labled on the cap.
Car: 88 camaro
Axle/Gears: 3.55
Yes it looks just like that distributer in the picture but my question is what on my cars wiring do I hook up to that 2 pin connecter on the distributer? there is no connecter on my car that will just plug into the new distributer ya know what I mean,there is only one plug in on the new distributer and my old distributer had 2 on it,do I need to hook something up from my old distributer to my new one?
everyone i have ever seen had two 1 wire plugs (not including the one in that dist. pic) 1 is white (tach) and one red ( +12v ignition)
found a pic
found a pic
Transmission: 4L80E/4L80E
The factory small-cap coil wires are pink and white. You buy connectors like Brando showed and splice them into to those two factory wires.
You don't need to hook up any of the wires from your factory distributor. Just the pink power wire to BAT, and white tach wire to TACH.
If he hooks it up to the pink coil wire, it will be switched 12v.
92camaroJoe
Aug 13, 2015 06:07 AM
