Engine I.D Help please.
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Ok someone please help me. i have a suburban outside of my house. ive been looking to get a 350 engine. finally for some reason i checked to see what engine the suburban had and it seems like a 350 but idk. can someone help me identify it by looks?? here is a video of the engine.
the suburban does NOT run but the engine was alfays in good shape because it was new.
Here it is: http://www.youtube.com/watch?v=FmSoc9kqBek
Someone help me please. hopefully it is a 350. it is not the original motor that is supposed to be in the car.
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Re: Engine I.D Help please.
It could be a 305 or a 350. Suburbans did have 305s. The only way to be sure is to check the casting number on the back of the block. I almost got screwed over with an engine i was going to buy on craigslist. The guy said it was a 350 and said it came out of an 86 suburban. Drove to jersey to go see it and the casting number proved it to be a 305.
Car: 86 Sport Coupe
Engine: 5.3 LM7
Its molded into the block and probably covered with a thick layer of grease or paint.
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
yea, i see what you mean now, my problem is that the engine is too far back to the firewall so i cant see it good.
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Get a flashlight and a mirror. For some reason I thought it was on the same spot as that circled but on the drivers side. It should say 5.7 or 5.0
Transmission: 4L80E/4L80E
Sticker? On the front of the engine? Where?
Don't believe stickers.
The last three digits of the block casting # is usually cast into the side of the block, viewable from underneath the vehicle. Much easier than trying to use a mirror between the firewall and back of the head. The last 3 digits are all you need to identify the block.
anyone that knows what type it is for sure?
