Fuel Pumps for Stock CCC Quadrajet 305
Old Mar 20, 2012 | 06:18 AM
mph870's Avatar
Car: 1987 Camaro SC
Engine: CCC Quadrajet 305
I have a stock 1987 Camaro with a CCC Quadrajet 305 VIN "H". I'm getting conflicting information for my fuel pump. I have the mechanical pump on the block, but one source tells me that I do have an in-tank electric pump, and another source tells me that I don't have one. I have the relay on the firewall and the wiring to the tank, but I don't hear one when I start the car. My car starts, runs, and drives OK, but I'm trying to trace an intermitent stalling problem to my fuel pump, ignition, or carb.
Do stock carbed 305's have an in-tank electric fuel pump?
Thanks,
Old Mar 20, 2012 | 10:01 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: Fuel Pumps for Stock CCC Quadrajet 305
Since yours is an '87 you have both an in tank pusher pump and a mechanical pump.
I can't hear my in tank work in my 1984, but the pump is a PUSHER pump, which means it isn't powerful (2-3 psi IIRC). To check, disconnect your rubber fuel line at the pump and turn the key to the ON position. If fuel flows freely and is pushed out faster than a gravity feed, your pump is working correctly.
For the mechanical, Carter makes a direct replacement pump that supports 450 HP. I put a brand new Carter on my engine. My only complaint is that outlets are weakly cold soldered and one broke while HAND tightening. Summit replaced it for me and so I taped off and JP Welded the next one (nothing sloppy, it looks perfect).
Old Mar 21, 2012 | 06:10 AM
mph870's Avatar
Car: 1987 Camaro SC
That's what I thought.
I'll disconnect the line to see if the pusher pump is working.
Thanks,
Old Mar 21, 2012 | 07:10 PM
RocketyMan's Avatar
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
For the me.......off and JP Welded the next one (nothing sloppy, it looks perfect).
Do you know if there is a RPO code for the in tank pusher pump??
I've looked under my '84 camaro and I cannot see anything near the tank that implies there being a pusher pump inside the gas tank. I also hear nothing too when I turn the key.
My car runs fine, I'm just super curious.
Old Mar 21, 2012 | 07:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It wasn't an RPO code. All '87's had it, most L69's had it. Some other carb'd cars had it added as a dealer kit if the owner complained about vapor lock problems.
Odds are your '84 does not have it.
Old Mar 21, 2012 | 09:24 PM
Engine: L69
Transmission: A4
My '84 has no indication near the gas tank that it has the pusher pump either. If the pusher pump fails, the mechanical will still pull gas through the failed pump.
Edit: Another way to tell if you have the pusher pump is to follow a light brown/tan wire that goes into the grommet near the brake booster to under the dash.
Old Mar 22, 2012 | 01:06 AM
five7kid's Avatar
Sort of. Pumps are better at pushing than they are at sucking. When the in-tank electric fails, it sets up conditions for classic vapor lock. The failed in-tank pump should either be replaced, or removed.
Old Mar 22, 2012 | 06:17 PM
RocketyMan's Avatar
My '84 has no indication near the gas tank that it has the push.......l pull gas through the failed pump.
Can you show a picture? I think I know of the tanish wire on the brake booster, but I don't see how that would tell/do anything in relation to the pusher pump.
Well my '84 is an L69...soo wouldn't it have it? I'm guessing since it was an earlier L69 it wouldn't have it.
Old Mar 22, 2012 | 08:11 PM
Engine: L69
Transmission: A4
First Quote: I don't have any pictures on hand of the wire that I can think of. Easiest thing to do is find a 1986-1987 wiring diagram. When the dealerships installed the pusher pumps they used the exact same wires/diagrams/everything that they ended up using in 87.
That tan wire runs all the way to the back, giving power to the pump. If you have a factory service manual there is a page that shows all the relays under the hood. If you find an extra one near the brake booster, then you have the pump.
Second Quote: Not necessarily. It all depends if a previous owner had the recall done or not.
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
