Changing primary jets
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
Had my quadrajet rebuilt and the shop said its still running a lean. It gets up and goes great but if you hit WOT it tends to bog a little bit and doesnt want to go as easy. I have .076 jets in it right now, the shop said I should consider going up to either a .079 or a .082. First off is that to big of a jump and second would I need to change my primary metering rods if I jumped up jet sizes? I have Cliffs kit on my carb but he only sells up to .077 on his jets.
Transmission: 4L80E/4L80E
You need to tune the secondaries, not the primaries. Only the primaries have jets.
The secondary rods & hangers, and the air valve opening rate are where you need to concentrate. A bog means the air valves are opening too quickly, which causes a lean condition.
The choke pull-off and air valve spring tension are the first two things you need to address. The choke pull-off can be checked with a vacuum pump - the usual failure mode is failure to hold vacuum. It can look like it's functioning when the engine is running because the engine supplies a steady vacuum. But, a leak in the diaphragm can allow the pull-off to release too quickly.
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
