Converting Elec Fuel Pump to Mechanical
Old Apr 6, 2012 | 07:29 AM
jloomis95's Avatar
Car: 1992 CAMARO RS 25TH ANNIVERSARY
Engine: 3.1 V6
Transmission: AUTOMAGIC
Axle/Gears: STOCK
Hello, Just pulled out my fuel injected v6 and put in a v8 carb. It had a in tank elec pump. I am converting to a mechanical pump and was wondering if i could use my old sending unit if i pulled out the elec pump and replaced in with hard line going down into the tank? and is there any other major changes I need? Thanks for any and all info!
Old Apr 6, 2012 | 08:05 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Converting Elec Fuel Pump to Mechanical
this method has been pretty well noted here:
https://www.thirdgen.org/forums/carb...nk-pickup.html
it is doable, shouldn't require anything else done to the sending unit otherwise.
Old Apr 6, 2012 | 08:19 AM
jloomis95's Avatar
Engine: 3.1 V6
Axle/Gears: STOCK
Thanks for the info, answers my question perfectly!
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
