Holley carb air bleed tuning....
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
So, finally after messing with my old 4150 and e85 and never being able to dial in the afr, I upgraded to a HP. Still running a bit fatter than I want at idle, I am thinking I could fine tune the air bleeds to get my afr just right.
Who all has experience with the air bleed tuning process, is it the same as jetting or more touchy? I picked up these 2 kits today: http://www.ebay.com/itm/250927336098...#ht_1043wt_906
http://www.ebay.com/itm/260889500910...#ht_1043wt_906
I am running e85, (more like e75 right now with the blend they are running) but once the e85 is back to full strength I plan to fine tune the car for e85, and when I get that random tank of <85% ethanol it will simply run a tad rich.
Just looking for simple advice from anyone playing with the adjustable airbleed systems on Holley based carbs
Transmission: 4L80E/4L80E
Car: 82 Trans Am
Transmission: t-56
Re: Holley carb air bleed tuning....
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
