TPI-carburetor swap, will this work?
Old Apr 14, 2012 | 02:47 PM
GTAStockholm's Avatar
Car: -88 Trans Am GTA
Engine: 305TPI / 456hp 383cui
Transmission: T5 / T56
Axle/Gears: 3.45 9bolt
Im in a swap from efi to carb project.
Car is a 88 trans am gta (305/T5)
Car has a Walbro GS255 in tank fuelpump.
New engine is a built 4 bolt main 80-85 truck block.
Forged 383 crank, pro comp heads e.t.c..
Engine is tuned to 456bhp and will be assambled to a 96 T56 gearbox.
My question is will it work with stock fuel lines and Walbro in tank pump, and a regulator like a Mallory 4309 3 port 3-12 psi? Will fuel flow be ok to 450 hp?
Sorry for my bad english, im from Sweden
Old Apr 14, 2012 | 11:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The stock lines are good to over 500 HP, so no problem.
(And, your English is better than a lot of Americans... )
Old Apr 15, 2012 | 03:30 AM
Re: TPI-carburetor swap, will this work?
Ok thats good, but will the bypass-style mallory 4309 flow as much fuel as required for 450hp?
If it will work, i do not need to take my fuel tank down and replace the in tank pump and so on..i do not understand why not all efi - carb swappers use a bypass regulator?
Old Apr 15, 2012 | 10:29 PM
five7kid's Avatar
The regulator will be fine. 4-6 psi is all you'll need.
Sounds like you're ready to go.
Old Apr 16, 2012 | 12:46 PM
I know 4-6psi is good, but psi is not the same as flow?
I buy it and hope it work
Thank you for all help!
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
