Fuel Line
Car: 1983 Trans Am
Axle/Gears: Stock
Fuel Line
Still working on my Rodchester Quad. Have a Edlebrock fuel pump and I
found a hose not hooked up to anything,could this be the vapor return line because the fuel pump only has a in and out or does it go somewhere else.
Al
Al
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Fuel Line
I know the EFI has a pressure line, return line, vent line and EVAP canister line from the tank. The vent line doesnt go past the rear end so only 3 lines come to the front of the car. pressure line is 3/8" the return line is 5/16" and the EVAP line is 5/16". Im not totally sure what the carb setup is but it should be close to the EFI stuff.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Fuel Line
the stock block mounted fuel pump was a return style. Should be two lines going along the right fenderwell. The smaller is the return to the tank.
I'd recommend getting a return style pump. The return was designed to help prevent vapor lock and fuel boiling issues.
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
