QJet Carb.
Old Apr 20, 2012 | 03:35 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
QJet Carb.
Still trying to get my QJet Carb. right, now it idles way to high. I cannot adjust the idle screw anymore. Does anyone have ant suggestions. I should have bought the rebuild one on ebay. Or should I change the whole thing to a Edlebrock preformer. Thanks for all your help guys.
Al
Old Apr 21, 2012 | 12:14 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are two idle speed adjustment screws, one for the choke on the passenger side of the carb, and the other for the "normal" idle on the driver side. Push that green weight down that's on the passenger side and see if the idle goes down. If it does, then it's your choke idle (aka "high idle" on the emissions sticker) that's too high.
Old Apr 21, 2012 | 01:25 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Re: QJet Carb.
Thanks,
I need to rebuild it, does anyone know how to disc. connect the cable going down to the
trans. I think its called a TV cable,has a little end on it, cannot get if off the carb.
Thanks,
Al
Old Apr 21, 2012 | 01:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: QJet Carb.
Pull the little end forward.
Old Apr 21, 2012 | 01:54 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Re: QJet Carb.
OK, But don`t pull it off right. Tried could not do it. Will try again.
Old Apr 21, 2012 | 02:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: QJet Carb.
Pull it forward until it comes right off.
RedLeader289
May 28, 2019 01:47 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
