Intake+Carb clearance?
Old Apr 26, 2012 | 10:26 PM
Rabble's Avatar
Searched this and went through a few threads, couldn't find anything relevant.
I'm looking into buying an Edelbrock RPM Air Gap and Holley 750 DP. Will there be clearance problems with the stock hood? Is anyone running this combo? Mainly worried about the added height with the Air Gap intake.
Old Apr 26, 2012 | 11:20 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: Intake+Carb clearance?
I have the RPM intake and believe me, it does not fit.
I've read that it does, but there is no way in hell it does for me (stock hood).
If you don't have the CC carb, which you don't but I do, you can use the old Corvette drop base. They are a 2 inch drop and will work fantastically.
Old Apr 26, 2012 | 11:24 PM
Rabble's Avatar
I plan to upgrade to a 2" cowl hood later on. So I'll just have to wait for that then. Thanks
Old Apr 27, 2012 | 07:53 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Air gap and 750 Demon fits fine under my stock IROC hood (1990). You need the L88 drop base (reproduction), a 3" filter and flatten the lid a little. The L88 drop base does hit the HEI, so you need to "adjust" it a little. I have about 1/2" clearance at the front of the lid.
z 28 jari
Sep 14, 2021 10:03 PM
91 SrS
Oct 7, 2015 04:32 PM
86z89iroc
Oct 5, 2015 01:04 PM
Night rider327
Sep 16, 2015 02:20 AM
