Hesitation problem. Need some help here guys
Old Aug 25, 2012 | 04:37 PM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
I rebuild my 84 camaro's 305 engine along with the carb. It runs great the only problem is if I'm at a red light or stop sign or if I have to pick up speed, I can't easy the pedal otherwise it hesitates. I have to give it some serious gas. I know if it was a accelerator pump problem it would hesitate with heavy acceleration. Any ideals?
Old Aug 25, 2012 | 04:59 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Hesitation problem. Need some help here guys
You rebuilt the carb.....do you have the tools and gages to set mixture control solenoid limits?
How's the float level and float drop?
Did you uncap the idle mixture screws and remove them? Is the idle mixture adjusted correctly?
I'd still check the accelerator pump circuit. Look down the carb throat (engine off) and slowly open the throttle to full. Even with opening the throttle slowly, the pump should still squirt just as it starts to move.
Old Aug 25, 2012 | 05:04 PM
Jfinnkma91's Avatar
Th idle mixture screw caps r off. And i used a vacuum gauge to get highest vacuum. Accelerator does squirt a small amount of gas when throttle is slowly pushed. And no I dnt have a air/fuel mixture gauge
Old Aug 25, 2012 | 06:00 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Unless you re-establish a baseline by having the carb adjustments correct, it'll be a crap shoot finding and fixing the cause of your off-idle hesitation.
Hopefully, the link might help. I wonder if you can rent the gages and adjusting tools from Autozone, etc.
http://quadrajetparts.com/rochester-...h-t-12_19.html
Edit: Here's another link with tool numbers.
http://www.chevyasylum.com/tech/carbtool.html
Old Sep 7, 2012 | 10:06 AM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Check the fuel pump pressure, too!
Old Sep 7, 2012 | 10:36 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If this is the computer controlled q-jet, AFTER setting the mixture control solenoid limits, you'll likely have to set the idle mixture screws and IAB for dwell at idle. If dwell is out of whack so that the ECM can't command a proper air/fuel ratio you'll get off-idle hesitation.
Did you return the settings for the idle mixture screws, rich stop, lean stop and IAB back to their original settings on rebuild? Did you verify TPS function and setting at idle? Have you confirmed base timing and proper timing advance?
You won't be able to get the gauging tools from Autozone, but come back, answer some questions and I can help you get there.
Old Sep 7, 2012 | 11:09 AM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
I have the very same issue that the OP is experiencing. I bought my '85 T/A last October and the car is equipped with the 305 which is completely stock. The car idles fine at 700rpm after warmup. I believe the carb is also original. I have often wondered if the accelerator pump is shot. I went to a site called www.florida4x4.com/tech/quadrajet/index.php that had a lot of good information. I just haven't been annoyed enough to take it apart. Oh, and the timing is spot on and there are no other engine related problems, only the off-idle hesitation.
Old Sep 7, 2012 | 11:48 AM
naf's Avatar
naf
You can verify proper booster pump action by looking for a fuel shot into the primary barrels as the throttle is opened. You should see two streams of fuel going into each bore.
Probably not the issue if the hesitation only occurs on light throttle opening.
Old Sep 9, 2012 | 11:14 AM
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Have you had any success getting the hesitation problem fixed?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
nuggie
Aug 25, 2015 01:27 PM
Street Lethal
Aug 14, 2015 08:25 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
