How do i adjust air fuel ratio on carb
Old Aug 28, 2012 | 08:20 PM
Shep5B's Avatar
Car: 1985 IROC-Z H.O. 4bbl
Engine: L69 Small-Block, 305
Transmission: Borg-Warner T5
I have a 1985 iroc 305 H.o... I was wondering how i could change the air fuel ratio on the carb . Because it seems to be. That when i rev the car up and then let go.. It starts to drop in rpms untill it hits zero and then the car shuts off
Old Aug 28, 2012 | 09:32 PM
5spd-iroc's Avatar
Car: '85 iroc-'13 powerstroke H&S tuned
Engine: 406 sbc full roller
Transmission: t5 soon to be t56
Axle/Gears: stock
Re: How do i adjust air fuel ratio on carb
i would check your idle adjustment
Old Aug 28, 2012 | 09:37 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Also check for a loose idle stop cam or linkage also your idle boost solenoid.
You may just have a vaccum hose leak which also effects idle speed.
The idle mix adjustment screws are "sealed" in the stock Q-jet.
Old Aug 30, 2012 | 06:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
This is one of those rare cases where it would be best to determine the cause of the problem before you start to fix it.
Old Aug 31, 2012 | 07:53 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Right on five.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
