Edelbrock carb help needed
Old Oct 7, 2012 | 09:24 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Its a 750cfm electric choke performer so my problem is the top butterflies on the secondaries dont open but maybe 30% of the time. The bottom set of secondaries open mechanical and work fine, the top set moves freely, no vaccum leaks, electric choke works fine ive also changes the metering rod springs. Any other ideas? Can i just remove the top butterflies? Thanka for your time.
Old Oct 8, 2012 | 09:05 AM
JaBoT's Avatar
Re: Edelbrock carb help needed
There is nothing wrong with it. They usually don't open all the way. They will only open for as much air as the engine wants. That's how a vacuum secondary works. You have a stock cammed 350. It doesn't need or want 750 cfm worth of air.
Do not remove them. You will turn the carb into a double pumper without the secondary pump and will bog when you get on it.
Old Oct 8, 2012 | 10:42 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
What he said. Unless you crank your engine to 8000RPM or so it's not going to open. That's a pretty big carb for a 350, you might like a 650CFM better on the street.
Old Oct 8, 2012 | 08:27 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Well thanks for your input but there was an issue with the carb got it fixed and car runs awesome.
IROCZ1989
Jan 24, 2016 03:55 PM
86IROC112
Aug 17, 2015 02:00 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
