Cable setup.
Old Oct 18, 2012 | 05:03 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Cable setup.
How do you guys set up your detent and throttle cables? Mine seem way too long to go to the carb
Old Oct 18, 2012 | 05:28 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Cable setup.
Best thing would be to use throttle & TV cables from a carb or TBI motor if you are swapped to carb from TPI. You will also need a geometry corrector if you swapped.
Old Oct 18, 2012 | 07:14 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Cable setup.
You can always loop the cable around if you need to.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
tattmann
Sep 27, 2015 05:20 PM
