holley carb
Old Oct 27, 2012 | 10:24 PM
84merrittZ28's Avatar
holley carb
ok so i have an all stock 1984 Z28. i bought a brand new holley carb to replace the gummed up stock rochester carb. problem is the new holley doesnt have the electronic hook ups for the choke lights inside the car so it stays on and there is a horrible buzzing noise. Any idea if there is a plug for these wires to counteract the warning light plugs ?
Old Oct 27, 2012 | 10:27 PM
Re: holley carb
another thing is the old air cleaner doesnt fit anymore and there was a hose connecting into the engine block, can i just plug this hole in the block? or do i need it to be open?
Old Oct 28, 2012 | 03:21 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: holley carb
Lots of problems here. You can't just replace the old computer controlled carb with a Holley. You need to replace the distributor too. And you probably want a choke (you need to go manual choke or an electric conversion on the Holley. You need a different air cleaner. If it is an automatic, you need the correct geometry bracket or the overdrive transmission wont work quite right. Do a search on this site...plenty f people have been through this.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
sreZ28
Oct 22, 2015 08:21 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
makaveli09
Sep 15, 2015 10:43 AM
WickedBowtie
Sep 11, 2015 11:24 PM
