throttle return spring
Old Oct 27, 2012 | 11:09 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
can anyone tell me how to set this up? i just did a v6-v8 swap and am finishing up a few small things on the motor before its ready to rock and roll and i cant figure out where my return spring goes. iv got an eldebrock preformer 2116 intake, eldebrock kickdown bracket, carter 4b carb on my vortec motor. help?
Old Oct 28, 2012 | 07:34 PM
Engine: L31 350
Re: throttle return spring
bump
Old Oct 29, 2012 | 09:14 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
No place on the throttle cable bracket? Usually a small hole somewhere on it to loop the spring in.
Can always fab a quick simple one out of a piece of flat metal. Bend into an "L" shape, drill one end to put under a bolt in the intake, drill small hole in other end for spring, pull spring to throttle.
Old Oct 29, 2012 | 09:17 AM
3rdgenmaro's Avatar
Car: 88 IROC
This is my quick bracket on my s10.
Maybe you can do something like that?
Old Nov 2, 2012 | 10:12 PM
Engine: L31 350
I just hooked it to my valve cover lip till I can make a bracket
Old Dec 1, 2012 | 12:54 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
I just bought a universal one from AZ for $4.
Old Dec 1, 2012 | 04:43 PM
Yellow3gZ's Avatar
oriellys and autozone both sell universal/adjustable throttle cable brackets that have a hook loop on them for the return spring.
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
maroe624
Apr 16, 2017 08:29 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
f-bodyz28
Sep 2, 2015 05:03 PM
