In-tank electrical and mechanical pumps
Old Dec 1, 2012 | 12:07 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
in-tank electrical and mechanical pumps. Can I run both? Im using an Edelbrock 750 on a 5.7 sbc. Both are brand new and already installed. The car isnt running yet as im still putting the car back together so i cant test it yet.
Old Dec 1, 2012 | 01:53 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
re: In-tank electrical and mechanical pumps
If you have an in tank pump, then just use it and get a block off plate for the engine. You will probably need an adjustable pressure regulator especially if the car was fuel injected before. If so, it will have a high pressure pump making way too much pressure for a carb.
Old Dec 1, 2012 | 02:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes you can use both if the mechanical pump has a return line.
Old Dec 1, 2012 | 10:09 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Great, thanks! Yes, my mechanical has a return line. Should i run that right to the 5/16 return line that runs to the tank or to the charcoal canister first, then to the return line?
This is my first car project, which has ended up being a frame off restoration and im learning as i go. I was told my brother (whose a Ford guy) that i should replace both, but have read some conflicting information elsewhere. Actually most of what he says isnt completely accurate and i get almost all my help here at TGO through searches and questions.
thanks again!
Old Dec 1, 2012 | 10:11 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
yeah the car was a TBI originally. Will the mechanical pump regulate the fuel pressure or do i still need an adjustable regulator?
Old Dec 2, 2012 | 10:36 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Return goes to the tank.
Old Dec 3, 2012 | 02:00 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I wouldn't run that mechanical pump at all with an in-tank pump.
I also wouldn't trust the mechanical pump to regulate the fuel pressure. Your best bet is to bypass it completely and get a Mallory 4309 bypass style regulator (bypass = return). Holley also makes a few models that will work.
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
fbirdroller
Sep 2, 2015 10:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
