Holley 4160 and Fuel Filter
Old Nov 11, 2012 | 07:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My 4160 came without a fuel screen (#26-141) or the bronze/spring type (162-500) in-carb filter. While I've always run a canister/paper filter after the pump, I wonder if I'd be well served to use the 26-141 as a precautionary measure. Any thoughts?
BTW, I haven't been able to find a picture of the 26-141 to save my backside. If anyone has a pic....
JamesC
Old Nov 11, 2012 | 08:30 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Holley 4160 and Fuel Filter
Can't hurt. I've got a piece of rubber line between my filter and the carb inlet, and had no carb filter. Have had pieces break off the inside of the line a couple times, and get caught in the float valves with the resultant flooding problems. So I fitted a bronze filter last carb overhaul. If I was real smart, I'd get rid of the rubber line, on the to-do list
Old Nov 19, 2012 | 05:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Holley warranty requires you to run the bowl inlet filter regardless of any other filtration you may have.
Old Nov 20, 2012 | 12:18 PM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I agree with the two above. Even though you have a filter in line, you still can get materials post filter get into the carb and mess things up. Not only have a float stick like mentioned above but material can get stuck in the bleed lines or boosters and cause tuning issues.
TreeFiddy - you should check into getting the teflon coated fuel lines. They cost more but they last longer and stand up to the additives and new fuel blends better than the old rubber/braided fuel lines.
Old Nov 21, 2012 | 09:01 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Yeah I should look into doing something. It's a yearly 'summer tuneup' ritual now to replace the rubber line, with another chunk cut from the cheap roll I bought, hanging on the same nail on the garage wall for years. Think I'd have learned eh
Old Nov 21, 2012 | 10:39 AM
JamesC's Avatar
Interesting to note that Holley says to remove the inlet filter under race conditions.
I'm not currently running the 26-141 filter shown below (for the first time anywhere as far as I can determine), but I may throw it in as soon as I get the choke/fast idle adjusted to my satisfaction.
JamesC
Attached Thumbnails Holley 4160 and Fuel Filter-img_0692.jpg   Holley 4160 and Fuel Filter-img_0693.jpg   Holley 4160 and Fuel Filter-img_0694.jpg
Old Nov 21, 2012 | 02:47 PM
five7kid's Avatar
Really. I'd never seen that.
I just ran sintered Fram filters in the inlet. Never had any problems, even with E85 under race conditions.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
