Which carb feed lines?
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Well ijust got myself a 750 holley ultra double pumper and now need to buy carb feed line. Which one do u guys recommend? Maybe one with a fuel gauge or one where i can install one? Im kind of new to carbs so im not sure what to go with so plz help
Transmission: 4L80E/4L80E
It doesn't take anything fancy.
http://www.summitracing.com/search/p...%20fuel%20line
I would NOT get anything Mr. Gasket, though. Cheap, cheap, cheap stuff. Which leads to the next problem, dangerous. I was desperate and got one a few years ago when I couldn't get anything else, just about caught the car on fire. Replaced it with a Spectre and didn't have any problems with it.
Summit brand, okay. Spectre, probably no problem. Holley, good stuff. Mr. Gasket, avoid.
Engine: 350ci TPI
Re: Which carb feed lines?
Wow well thanks for the heads up. Ill look in to those thanks,
Car: 1989 Formula 350
If you want it to be real nice, you can use braided line and AN fittings. They make the feed line setups in braided also.
Engine: 350ci TPI
since my carb is a ultra series double pumper would that take a different type or feed line or would any of those in the link above fit it? and which one would be better the -8AN or -6AN ?
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Your supply line is 3/8" which equals to a -6AN. No sense in spending more on -8 stuff when there is no benefit in it. As far as Spectra stuff, I've seen both good and bad from them. Most of my braided hose stuff is from Aeroquip and the carb connection I got whole from Summit.
Easy way to remember the "dash" to pipe size is this--> "dash#"/16 = -6/16 or 3/8"
theshackle
Mar 5, 2017 06:37 PM
