Efe stuck closed?
Old Jan 8, 2013 | 12:15 PM
native1031's Avatar
Efe stuck closed?
On a stock 305 ccc
If the efe actuator was stuck closed in the exhaust could it cause a back fire through the carb?
If not what would be some symptoms of a closed efe, thanks!
Old Jan 8, 2013 | 01:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Efe stuck closed?
IIRC, the default on the EFE valve is open.
JamesC
Old Jan 9, 2013 | 01:19 PM
Damon's Avatar
Um.... no, I don't think so. At least I haven't encountered backfiring due to it sticking closed. But it'll sure feel like somebody stuck a banana up your tailpipe when you dip deep in the throttle.
Just pull the vacuum line off the TVS switch up near the intake and apply/release vacuum to it while you watch the arm on the side of the EFE valve move. It's pretty obviousl if it's working properly. There's also a one-way check valve in that line that sometimes goes bad and holds vacuum at the EFE, causing it to stay closed constantly, regardless of engine temp or manifold vacuum.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
