?'s about fuel pump for carb'd 454
Old Mar 24, 2013 | 11:32 AM
86mailman's Avatar
Car: 86 Iroc
Engine: 496
Transmission: 4l80e
Axle/Gears: 9" eaton posi 4:11
hopefully, you will be able to help me with my issue. I have an 86 iroc i just put a bb 454 in. Carburated. i want to run an exterior eletric pump. what modifications do i have to do to the intank pump? And do i have to have a return line, or can i just cap it off? any help will be highly appreciated. pictures would be awesome too.
Old Mar 25, 2013 | 01:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If the in-tank electric pump isn't operating, it needs to be removed regardless of what other pump you use.
Whether you need a return line depends upon the pump you end up using. Some are okay without it, others need it either to control pressure, or to keep cool.
In our cars, a return line is a good idea because of the heat in the area the fuel line runs through.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
