check valve in the fuel line?
Old Apr 4, 2013 | 11:01 PM
SuperHawk996xx's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
OK, I have been having a problem with my carb draining back into my fuel line when the car sits for awhile. Has anyone ever installed an check valve in the fuel line to prevent this? Also, I have a clear plastic fuel filter and sometimes even when I have a full tank of gas the filter will start to be empty. Kinda like fuel boiling but not. What could cause this?
Old Apr 5, 2013 | 09:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What carb do you have? The factory used an inlet filter that included a check valve.
Those clear filters are dangerous, especially if plastic (not much better if glass). I highly recommend getting rid of it and putting in a metal can type filter.
Old Apr 6, 2013 | 09:09 PM
Re: check valve in the fuel line?
I have always ran the plastic filters and had good luck with them. I am running a EdleBrock 650 cfm with Edlebrock intake. Mechanical fuel pump.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
