570 CFM Four Barrel Carburetor
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
I am looking into this carb for when I do my 2.8 v6 engine swap to a 305, This carb sounds like a really good fit, but Im not to sure if this carb can be put on a 305, any information would be awesome.
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Re: 570 CFM Four Barrel Carburetor
I have that carb on my 305. Holley 570 Street Avenger with quick change vacuum secondary spring, secondary metering plate with interchangeable jets and std dual fuel feed set up like a double pumper. You will need an aftermarket intake to fit the carb or if the 305 has the stock intake you will need an adapter. The adapter makes it hard to get a good air cleaner on the car. Your better off going with a performer or similar intake to start with.
Hotrodboba400
Dec 10, 2019 07:07 PM
sreZ28
Oct 22, 2015 08:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
