How expensive to replace distributor?
Old Apr 26, 2013 | 10:59 PM
jay83z28's Avatar
Car: 1983 Camaro Z28
Engine: 5.0L V8 Carb
Transmission: 700-R4
How expensive/difficult is it to replace the distributor? I wont be going with a Qjet since I've had some bad experience with mine, but I'm on a tight budget. My car's a stock 83 Z28 with the 305, New York car, smog exempt.
Old Apr 27, 2013 | 02:38 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Not sure which Carb to get
They run about $100-$150 from your local parts store for a general non-computer controlled version. Replacing it isn't hard, as long as you mark the position of the rotor when you remove the old one relative to how it is sitting in the car before you remove it. Line up the new one to how the old one was sitting. Otherwise, you need to crank the car over until the #1 cylinder is TDC and do some other measureing to make sure. So just mark it. Or, have a shop do it. THat would be my preference, that way if they screw it up, they can build you a new motor.
Old Apr 29, 2013 | 08:52 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I wouldn't just scrap the idea of using the Q-jet because you now have problems with it. It's probably in need of a GOOD rebuild. Unless you have the ability to make sure that the carb isn't warped and can repair it, it's best to leave it up to a professional re-builder, not some local hack garage. I've had very bad experiences with national part store rebuilt carbs as well.
This is a cheaper option than having to buy a new carb, distributor, getting the ECM stuff removed and then tuning the motor. A new HEI dist - $90 (summit) to $170 (Mallory), New carb >$280
Old Apr 29, 2013 | 09:56 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I had my Qjet professionally rebuilt and that set me back $370.00 by Cliff Ruggles at Cliffs High Performance. He is a maestro at the Qjet. So, I think the costs sort of off-set, however, I am a proponent of keeping the factory equipment if you can (Obviously some modified stuff can't) so I will always propose options to keep what you have.
Old Apr 29, 2013 | 03:58 PM
Cosmik Debris's Avatar
Re: How expensive to replace distributor?
As well as the carb, and distributor, you will have to take care of the lock-up of your convertor. If you are on a tight budget it will be cheaper to fix what you have.
Old Apr 29, 2013 | 07:19 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
converter is an easy patch with the correct brake light switch and some wire
Old Apr 29, 2013 | 08:23 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Check out kmj performance, they got some hei's for like $70. Ive got one trouble free.
Orr89RocZ
Apr 25, 2016 08:28 AM
86IROC112
Aug 17, 2015 07:57 PM
ChevyZ71
Aug 13, 2015 07:30 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
