Did i wire the vaccum right?
Old Jun 10, 2013 | 03:52 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Alright so I got a couple of questions did I plug up the PCV valve to the carb correctly....i also sprayed some carb cleaner onto around them to check if i had vacuum leaks and it seems good....also was also wondering what is that solenoid next to me throttle cables do exactly?
and for some reason I am getting bad throttle response at idle....like wheni rev it it hesitates and goes up slowly...what could that be? ive messed with the idle mixture screws and have plugged up pretty much all of the vacuum leaks it had.
I am really close to junking this carb and buying an edelbrock carburetor....have been having so many problems with it.
Attached Thumbnails Did i wire the vaccum right?-camaro1.jpg   Did i wire the vaccum right?-camaro2.jpg
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
