Can I post QS about marine carburetors here?
I have trouble with acceleration from idol with my Rochester 2 barrel, on my 4 cylinder mercruiser inboard / outboard engine.
can I post my Qs. about it here and expect to get good answers?
I'm also located in NC so is this the proper page ?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Can I post QS about marine carburetors here?
The transition from idle accelerator pump aids to the circuit change. If the jetting of air bleed screws are not properly set at idle not idol the transition from a lean condition will result in a engine stumble.
Ever replaced the fuel filter? (about 1½" long and ¾" diameter, goes in the big nut behind the fuel line)
Transmission: 4L80E/4L80E
"Can I post QS about marine carburetors here?"
Here's the basics: Can the topic be applied to 3rd gen f-bodies?
Yes - Go ahead, ask away.
No - Sorry.
Now, there might be someone who has a 2bbl Rochester on their 3rd gen, but off the top of my head, I'd say there's been about 2 in the 13 years I've been on TGO. I think one bolted in a 307, the other an early 350, and kept the carbs that came on the engine. I don't recall them having issues with the carb, though.
So, tell you what I'll do: I'll go ahead and close this thread, and if anyone wants to help you out, they can PM you.
Fair enough?
Good, thought you'd see it my way.
No - Sorry.
Fair enough?
GeneralIesrussi
Sep 3, 2015 03:23 AM
