Rochester Carb top Module Help
Hi all, I came across a 86 T/A i picked up and it has a Rochester carb that has the top plug in it that has 2 wires a blue one and a black one, the blue one is just cut off 4 inches from the plug in and the black wire was ran across the drivers side to the firewall but cut off and cant find the other end where the black wire was cut off so I was wondering if anyone knew where these 2 wires were supposed to properly go. and more less what is the function of this module? my 87 formula never had a module on the top so that's why im kinda stumped where these should be hooked up.
thanks for any input
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Rochester Carb top Module Help
