Weird Vacuum Advance Problem
Old Jul 29, 2013 | 12:48 PM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I've been pretty lazy on getting around to getting the vacuum advanced hooked up but since I have done a lot to the motor this year (appearance wise) I decided to get this operational now. I put less than 500 miles on my car a year so it hasn't been a huge concern for me until now.
I went to set up my vacuum advance pot for what level I wanted it to be fully in and while using the vacuum hand pump I could not get any vacuum on the advance pot. After a few little experiments I found out that a check valve inside of the pot is installed backwards. I can pressurize the vacuum pot but I can't pull a vacuum, should be the opposite. Replacement part is $35
Just a warning to some of the newb's out there to never assume a new part is always good
Old Jul 30, 2013 | 07:43 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: Weird Vacuum Advance Problem
I've never had that problem, but I have had the diaphragm inside go south from oil getting in there. That is another thing to be on the look out for.
A vacuum hand pump is one of the best investments for a tool that I have ever made. Everyone should have one!
Old Jul 31, 2013 | 01:28 PM
bestracing's Avatar
Engine: Broke - 350
I have to agree it a must have for a DIY person......
...or at least talk a family member into getting one and then borrow it
Old Jul 31, 2013 | 05:52 PM
skinny z's Avatar
I'll be going through a complete testing of the vacuum advance over the next few days. I've already done some preliminary testing however I have to lock out the mechanical advance before I go any further.
The hand held pump is invaluable for this kind of work.
I have to thank my brother for having one!
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
