fuel sending unit
Old Oct 4, 2013 | 07:00 PM
aph415's Avatar
Car: 84 z28
Engine: 5.0L 305
fuel sending unit
First off my gas gauge is not reading right, I fill up the tank and it only marks 3/4 of tank, I told my friend about this he said it's the fuel level sender. So my question is this, can you replace only the fuel level sender instead of replacing the entire sending unit?
Old Oct 4, 2013 | 08:31 PM
Twin_Turbo's Avatar
Re: fuel sending unit
No, it is a single unit. ...but before you drop the tank, probe the sender wire and with a full tank check if you have around 90 ohms to ground. If you do, it's your gauge. Wouldn't be the 1st to go bad
Old Oct 4, 2013 | 09:01 PM
aph415's Avatar
Car: 84 z28
Engine: 5.0L 305
So it might not be the sending unit at all?
Old Oct 4, 2013 | 09:05 PM
Twin_Turbo's Avatar
investigate before tearing sh*t apart
Old Oct 4, 2013 | 09:35 PM
aph415's Avatar
Car: 84 z28
Engine: 5.0L 305
OK thanks for your advice
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
